blt2ski wrote:
Here in Washington, said 10k door sticker truck would probably have a minimum 12k legal gvw due to how this state licenses trucks. So you may want to make sure they do not ask for a copy of registration.
Here, take base wieght, times 1.5, to next higher ton.
If the truck empty wieght is 7000 lbs, times 1.5 equals 10,500. Next higher ton is 12,000. That's how much tonnage you would be required to buy. Even if the door sticker is less than 10k.
Marty
Yep, Washington with its goofy weight calculations. My old 2500HD regular cab gas only weighed 5200 lbs empty, so they tagged it at 8K even though GVWR was 9200.
