Bedlam wrote:
It may depend on what type of camping you do whether 1st gear is low enough. If you primitive camp, you may find the transmission laboring as you are trying back in or pull out of a steep view site. If your camping consists of paved resorts, you won't have to worry about gear ratios or break over angles.
If I am towing into a primitive camp then I will have a 4 wheel drive.
In low range that is the same as having a 7:46 rear end. That will give me more torque that the tires can hold even if I have a large 5th wheel in tow.
