RCMAN46 wrote:
Denny & Jami wrote:
Well it's obvious that very few here has actually changed gears in a truck and then pulled the same load like I have.
Denny
What transmission did you have on the truck you changed gearing on?
I've been around rving for a long time and built a few trucks to pull with but the one that had a 4 speed standard that I changed to 4.10 from 3.54 was the most noticeable but the C6 built with towing in mind and a RV stall converter was next, it was changed from 3.73 to 4.10 gears. Every other truck I've bought and used for pulling had the right from the start.
Denny
