Denny & Jami wrote:
Bedlam wrote:
Something else to consider is that you are putting less stress on the transmission torque converter or clutch on every initial start if you have a higher gear reduction in the axles.
That's also a very good point and another good reason to go with lower gears.
Denny
I agree with the lower gears helping remove some of the stress. Denny is towing very heavy, and needs the help of the 4.30 gears. I also agree that it is hard to compare the old C6, or E40D, to these newer 6-speeds. Gearing changes would be less noticeable, with the new tranny.
Jerry
