This is why I recommended 2015 and newer:
2015 Model Year Changes:
The 6.7L Power Stroke underwent significant revisions for the 2015 model year, most of which contributed to or supported the increase in output from 400 hp/800 lb-ft to a maximum 440 hp/860 lb-ft.
• Particulate matter sensor and sensor module added at the DPF outlet in order to measure filtration effectiveness.
• Fuel pressure and fuel temperature sensors for low pressure fuel system combined into a single sensor, no longer two individual sensors.
• EGR cooler flow redesigned, now using the high temperature cooling system (same circuit as the engine) instead of the low temperature system (which still provides cooling for the charge-air-cooler, fuel system and transmission cooler).
• EGR inlet temperature sensor added.
• Revised fan clutch design with additional heat sinks in order to more effectively dissipate heat, thereby improving durability.
• IROX polymer coated lower main bearings introduced for added durability at greater performance levels.
• Larger GT37 single variable geometry turbocharger replaces the GT32 twin compressor "DualBoost" turbo. Improved throttle response and high altitude performance. Wastegate eliminated, turbocharger produces ~30 psi at max load with an impeller speed of ~130,000 rpm.
• New lower intake, required to match new turbocharger.
• Manually activated, more effective exhaust braking system added, works in conjunction with new VGT.
• Upgraded high pressure fuel pump (injection pump). New pump looks identical, but features a longer stroke.
• Revised injector design, more efficiency nozzle design for reduced emissions and improved performance.
• Larger crankshaft damper with more mass.
• Strengthened cylinder head design.
• High capacity torque converter introduced, transmission shift schedule not significantly altered.
