rhagfo wrote:
shelbyfv wrote:
Apologies for the piggyback question but this seems a good place to ask. If I adhere to the payload door sticker (Combined weight of...should never exceed) do I need to be concerned about any specific axle or tire capacity? In other words, if I don't exceed the payload can I assume the rear axle and tires have enough capacity for the load? Just a general question, no specifics in mind. Thanks.
Hard question to answer with out knowing your payload, depending on what is carried in the TV, there are likely some combinations that it might be possible.
:h So even if under payload, it's still possible to exceed the rating for axle or tires?
