FishOnOne
Jan 26, 2020Nomad
Me Again wrote:Huntindog wrote:
In those conditions, it would be difficult to do a comparison, unless they were run side by side..
Another thing stuck out for me.
They said that their new standard was a perfect run is now 10 minutes... IIRC, it used to be 8 minutes. Either the climb has gotten longer, or the speed limit for the test has decreased.
Or was this a one time reduction due to the weather conditions?
They don't say.
As for the concerns about the temps.... Not an issue in these conditions. Run them up in the summer and it will likely be a different story
I would like to see the tranny ratios for each 10 speed tranny as well.
I fixed your post, so it is easier to read. Chris
In the video they said this is the new test standard for 2020 HD trucks which was very brief. Another change is the braking test now has a range of 35-40 mph because they're in a different weight category. Also the reason for using the cruise control was because of viewers request.
