cummins2014
Jan 26, 2020Explorer
Cummins12V98 wrote:
To have zero brake applications they need to be running at the speed they want to maintain then set cruise to say 5mph less but also lock the trans in the same gear you would have climbed that grade in. This will vary based on the grade and load. This takes a human to dial this in.
I easily maintained 30-35mph locked in 2nd gear on a several mile 14% grade at 33k combined simply by moving the cruise speed up or down with my thumb.
For the Cummins closer to 3k will give the best downhill braking.
Cool brakes along any big downhill grade = GOLDEN.
Although I am not towing the weight you are , I have never had to lock in a gear, it does it automatically when I set cruise on the descent . Mine will hold the setting on the cruise within 5 mph over. If it takes shifting down it does it. If I want to come off a grade at say 45, I set it for 40, and that is where it stays at 45. It seems we are arriving at the same , with doing it a different way.
