4x4ord
Jan 31, 2020Explorer III
ShinerBock wrote:4x4ord wrote:
If the GM had performed the way it should have people would have making excuses for why the Ford took so long getting to the top. Probably someone would have been blaming the turbo.
That is probably because the turbo and intake system plays a huge factor in how much power a diesel can make and sustain. If you put different turbos on the exact same engine/drivetrain and take it up the Ike, the results may be vastly different depending on how diverse the turbos and the intake systems are.
What I'm getting at is had the GM not had issues it would have run up the mountain in under 10 minutes. It really should have beaten the Ford. Had that happened fingers would have been pointing at why Ford's 475 HP engine couldn't keep up with a 445 hp Duramax.
