4x4ord
Jan 31, 2020Explorer III
ShinerBock wrote:
I think the Ram will be slightly worse than GM's time at around 12:00 minutes. Although I would like to see this test ran in 80F because I have a feeling it would significantly change the time of the Ford while not changing the GM and Ram times too much.
So you're thinking a poor performing turbo was the reason for the Duramax's terrible performance on this run and now you think the Cummins is going to do even worse? Does the Cummins have a turbo issue as well?
