Reddog1
Jun 21, 2014Explorer II
Mike@Asheville wrote:
I don't see an option here to post a pic so I'll describe it.
You will find this information on the RV.Net Tutorials and Picture related FAQ's
It should be relatively easy to see if a TC will fit on your truck. Park it beside a dually pickup, and compare measurements of the inside of the dually to your truck.
For the outside, measure the widest point of the dually fenders and compare it to the widest point of your truck, which may or may not be at the rear tires/fenders. If the sides of your truck bed are lower than the truck you are measuring, that is not a problem. TCs are frequently mounted on flat bed trucks. Very few TCs allow the use of the tailgate, so you may need to remove it from your truck.
Wayne
44,056 PostsLatest Activity: May 04, 2014
