Golden_HVAC
Jun 21, 2014Explorer
Francesca Knowles wrote:
Would a fiberglass bed withstand any stresses exerted on it by camper holddowns? It's been years since we owned one, but as I recall it was attached to the side rails and it seems like there must be a certain amount of movement-resisting stress imposed on those points when the rig's in motion.
Modern tie downs normally will not be attached to the metal bed side rails anymore, but instead will have brackets attached to the frame, that extend outward, and then the spring buckles will attach to that and the camper.
clicky
From this web site, you can find frame mounted tie downs.
http://www.torklift.com/index.php/products/tiedowns/talon-camper-tie-downs By the way, I did not say they are cheap. . .
I guess they can work - even when upside down. But I would not recommend trying this.
Next picture
Does your tailgate have 48" between the sides of the "U" opening? If you have that much clearance, then it should fit. You would need something like the Torklift bracket system, and perhaps if the camper extends behind the rear of the camper, you would want the dual tube "SuperTruss" hitch system.
picture 3
You can also see the superhitch has the rear camper mounts covered.
Good luck finding something!
Fred.
44,056 PostsLatest Activity: May 04, 2014
