How bad is the ride on the unloaded 450 when compared to the 350? How is it with the 5th attached? Does the turning radius improvement make up for the comfort difference? We're about two years ...
"Does the turning radius improvement make up for the comfort difference?"
Can't say that a turning radius is top of my list as it's not often it comes into play.
350 and 450 are both 14k GVWR, it you believe you should not exceed that number the 350 will give more carrying capacity before hitting the magical number.
