Grit_dog
Aug 22, 2020Trailblazer
So 4x4ord has a point with the overall gearing (Trans od ratios and rear gears) and power the engine puts out.
But What he is actually saying is the 4.30 geared Ford doesn’t “need” that low of gears and there may be a small fuel consumption advantage to the taller gears when cruising empty. I doubt you’d see any measurable difference hooked up heavy. Any small efficiency on the engine end of lower rpms will still have to drive through taller finals.
Likely a wash.
My old Mega is a good example of what I’m saying above. Even with taller than stock tires, the shallow OD ratio puts it at 2000rpms just a little over 60 mph and cruising at 85mph is like 2600-2700 rpms. Truck will do it all day long but I’ve driven similar trucks with a deeper OD and it seems the fuel economy is not much different.
So many conditions affect fuel economy, the gearing is only a small part of the equation.
Regardless of what the president of the Ram mafia says, by the numbers a new 4.30 450 Powerstroke IS king of the hill right now on all fronts when it comes to capability.
Likely a wash.
