RoyJ
Aug 28, 2020Explorer
ShinerBock wrote:
The engine output torque curve of a Cummins 6.7 is MUCH steeper than that at the lower rpm range.
On the left is the curve of a 350hp/800lb-ft Cummins 6.7L from similar to what my truck was stock but with 20 less hp. Max rpm is 3,000.
6th gear at 65 mph in my truck is a 1,370 rpm. 5th gear at 65 mph is 1,790 rpm.
I know the torque curve of a turbo-diesel is much steeper, I was referring to the steepness of the BSFC ringlands (320, 365, 410, etc.) on my graph.
If the curve of the 410 and 365 bends up vertical, so that 6th gear (1370rpm) high load lands above 410, and when you shift to 5th (1790rpm) low load, it falls to the 365 ringland, then you could get better fuel economy.
On my graph, this only happens once, where the 200kW constant power curve intersects the 275 BSFC curve @ ~3250 rpm. So running that engine at 3200 rpm WOT lands you in the 320 BSFC zone, with a downshift to say 4200 rpm, and 70% load, you land just within the 275 zone. But we'll need to see an ISB map like that.
