blt2ski
Aug 28, 2020Moderator
Shiner nd grit are where ii at on gearing. Slight difference.
If I ran empty frequently, 3.73 if available, 60 90+%of the time as I do, 4.10gears. 3.73if I only had a .7-.75 od to work with vs a .6-.65 dod.
Also depends on speeds you drive, what is legal, where grit and I are in Wa St, max over 10k lbs or towing is 60mph. So not sure the taller gears are in my favor, vs slightly lower.
My02
Marty
My02
Marty
