shartflhs
Mar 29, 2017Explorer
ORbiker is correct, I put a 6.0 trans cooler in, I also had an aftermarket cooler with electric fan prior. The aftermarket cooler was not enough. With both coolers installed I have never seen temperatures above 185 degrees, previously I had seen up to 220 degrees. I also did some mods to the trans while I did my engine mods, I installed a billet torque converter, and a transgo towing shift kit. Don't know if that helped with the temperature but it sure improved the shifting and off the line torque, much easier to get it going from a start.
44,066 PostsLatest Activity: May 13, 2026
