RCMAN46
Jun 02, 2018Explorer
RasMouSein wrote:RCMAN46 wrote:RasMouSein wrote:
I have the P3 it's great except in slow traffic, after a few second of crimping it automaicly apply a set braking... it make the trailer jerk...
The factory one should be best, because it check how much brake pedal is aplied and brake acordingly , just need to set how much your trailer needs.
But I have to admit, the boost mode on the P3 is great
You have too much boost for the size of trailer being towed. Dial down the boost and the jerk may go away.
Another thing that can cause jurk is too much play in the hitch system.
When I'm driving like 1 or 2 km/h, I'm braking, at first the controller sends under one volts, but after a few seconds it jumps to 2.5volts...
The 2.5 volts is the hold voltage which is 25 percent of max voltage controller is set for.
It will not activate until there is no deacceleration. You are not braking the tv only activating the brake lights thus the P3 goes to the hold mode after about 5 seconds.
44,066 PostsLatest Activity: Jul 25, 2018
