Farm_Camp's avatar
Farm_Camp
Factory installed Awning LED strip brightness.
I see many posts about outdoor lights, and lately folks adding the under Awning LED light strip.
My trailer (sig) came with one from the factory and, I kind of hate it.
Ok, hate is a strong word. I dislike the color temp (too white) can't do anything about that except to rip it off and start over.
My other issue is that it is waaaaay too bright for me most of the time. I was just reading another thread about too much light in campgrounds. I'm a "live and let live" kind of guy, but this LED strip on my camper... It's like standing on the surface of the sun when it's on. :)
Is there any way to dim these to control the light output if not the color temp? Can I just put a dimmer inline at the switch without damaging the LEDs long term?
26 days till camping starts for us! Yaaaaaaaaaaay! :)
  • Our TT has the factory LED lighting in the awning. I too don't like the color. It's cool white and just too blue-ish. It is really bright after dark and installing a dimmer would be a good idea.
    There is this LED dimmer on ebay listed for RVs. I can't get the link thing to work so you will have to copy and paste this: http://www.ebay.com/itm/RV-LED-Dimmer-Switch-BRAND-NEW-EXCLUSIVE-/281261224069 It looks like it will stay illuminated at night which may be good for some. I think I will look into using this dimmer.
    It looks like your light(s) need to be wired by the factory so that 12 volt power is run to the switch first. If it runs to the light(s) first, then you'll only have 2 wires to the switch and it needs continuous un-switched 12 volts. Or if you have 12 volts you can tie into nearby the switch, that should work.
    We have had a LOT of compliments in CGs on our awning lights.
  • SCVJeff wrote:
    Is it too WHITE or too BRIGHT?
    In LED world those are two completely different things. Bright you can fix for about $6 as mentioned above. White is a whole different problem.
    The answer is "yes". But I will settle for being able to dim it down some. Thanks for the information folks!
  • Is it too WHITE or too BRIGHT?
  • wmoses wrote:
    Just to let you know that your pictures may not be showing on all screens - they don't on mine.
    Thanks, how about now? This is the only message board I use that doesn't have image upload, so was linking from one that did.
  • pugslyyy wrote:
    I have a white LED strip, and also installed a second red strip. White is good for setup/cooking, but we like the red for hanging out.
  • I have a white LED strip, and also installed a second red strip. White is good for setup/cooking, but we like the red for hanging out.
  • I just did a google search "LED dimmer" and found these...
    http://www.ebay.com/itm/Single-Pole-LED-Dimmer-Switch-DC12V-72W-for-Standard-Wall-Switch-Box-TWD-202-/131046996079
    http://www.ebay.com/itm/110V-AC-LED-Dimmer-Switch-Adjustable-Brightness-Controller-For-LED-Light-Hot-/351036815702
    http://www.ebay.com/itm/DC-12V-24V-8A-LED-Bulb-Light-Dimmer-Switch-Brightness-Controller-Easy-to-install-/191119234768
    http://www.ebay.com/itm/12V-RF-Wireless-Remote-Switch-Controller-Dimmer-for-Mini-LED-Strip-Light-New-/221398621352
    Lots to choose from, but you first have to determine if the switch is 110v or 12v. The switches may not fit your switchbox, but that RF remote looks sexy!
