Frostbitte
Aug 12, 2015Explorer
IDman wrote:
For the last several months, I have been going at it with the dealer and factory over this issue.
My tank is supposed to be a 31 gallon tank, but based on total mileage per tank and the number of gallons it takes on fill-up, it is obvious that the tank is a 25 gallon tank.
When I purposely have run it "dry" several times, it will only take 24.5 gallons. I show them the receipts and they act like I am trying to act like that isn't proof of anything!
They have tried to give me every excuse imaginable but won't admit the mistake. Next week, they are taking the tank off the truck and taking it to a gas station to see how much it holds. DUH!
WITHOUT NAMING YOUR BRAND, have any of you had a similar problem?
If so, how was it resolved to your satisfaction?
Thanks in advance!
No, thank goodness no issues here like that.
Like the other said, check your VIN and build sheet. It should match. Also, get the part number off of your tank if possible and have them run the part number in the parts department. That'll tell you for sure.
