dshizzel's avatar
dshizzel
Factory Order RAM 3/4 Ton 2500
I'm looking forward to ordering a 2015 Ram 2500 from the factory. I've decided against having the 5th wheel/Gooseneck prep done since it seems to really only accommodate the Mopar frame/rail assy and seems to be a waste of money based on what I want to do (see below).
I want to get the short bed (6.4'). My last TV was a '99 QC LB.
I plan to get the RamBox storage management, and will offset the narrower space and shorter bed with a Sidewinder setup and standard 5'er hitch. I've read some posts in other forums that, on balance, indicate that 5'er towing with RamBox is not a problem this way. (eg, hitting the sides of the boxes when sharp cornering.
I'll likely end up with a Heartland 5'er with the angled front cap. Between that and the Sidewinder, I should be ok for maneuverability.
My question to the forum is what options would absolutely preclude the addition of the hitch. For example, the auto-rear leveling, or full size spare tire.
Any other advice you could offer would be great, as well.
Thanks!
  • For the few extra bucks, I would opt for a 3500 SRW. You may get a bigger trailer someday and you'd be surprised how fast you can eat up a 2500's rating. I know it's not as blingy as some other features but it makes it a strong tough truck.
    They ride the same too.
