westend
Jul 10, 2016Explorer
the problem with doing it more than once is each time some of the gel coat gets removed by cut sandingThat's true, material is removed but not enough that you would worry about it. The process involves rubbing compounds and the top, oxidized layer is very thin.
The advance of UV resistant clear coats is a boon for vehicles and RV's. The finish holds the body paint color for many years. I know there have been some gel coat advances as well. Keystone's issues with the front caps is unknown to me. Has anyone gotten an explanation from Keystone about the cause of the sudden cap fading?
