Yes, you don't state how long your time line is so all we can do is speculate on that. I am sure you can do math so you know how to figure out time/speed/distance situations. SO..... the only thing I will add is I 2nd the RVparky app for your smart phone. Also Google maps. The RVparky app will search the surrounding area you are in for rv parks on your route, even while under way on the hiway. We have used this often and have had great success and have never been shut out because of no reservations. We do call the CG to see if there are openings as a courtesy.
Google maps will help getting around construction areas on your route. I have gone to state specific dept. of transportation web sites to see the list of active construction areas. Then I plan accordingly to find a route around them if possible. RVparky will also show a good map of where you are at and possible ways around problem areas. Good luck, drive safely and enjoy your time at the coast.
