dadmomh
Feb 14, 2015Explorer
You're probably right....6' is a pinch in one of the standard bunks. Have you considered one of the areas with a sofa or jackknife sofa with a bunk above. Seems like I've seen some that have 2 regular bunks on the opposite side. While it's not ideal, you might even check out something with a sofa with an air mattress in the living area. Our DS#1 is 6'4 and he's fine on it, albeit a bit crosswise. Too bad the manufacturers don't often consider that 6'+ is a very common size and make some allowances. Good luck and happy shopping.
44,068 PostsLatest Activity: Jun 21, 2026
