Wes_Tausend
Dec 18, 2013Explorer
Fourkidletts wrote:
The rear axle is 3.73 it is an extended cab. I saw somewhere it was that much payload but now I'm seeing something closer to 1800 when I checked again. My parents saved everything on this and she had the original window purchase sticker in it. So I've got it all in front of me. I don't see a tranny cooler. I'm slowly starting to accept a trailer probably isn't going to happen for us right now. Im not sure i could drop tons of money into this truck with the mileage it has. But I know a whole lot about towing now, thanks to you all!
I'm sorry the Expy hasn't quite worked out for you the way you had hoped. I hope our more conservative members didn't discourage you too much, but they mean well.
If the RV controversy hasn't caused you to miss the good deal, perhaps the Expy would still work as basic whole family transportation. I'm quite sure your family doesn't weigh more than the six man railroad crews we typically hauled, plus a driver, using one of several Coach America Suburbans, so I am extremely confident that that 1/2 ton limited type passenger use would work for you.
Suburbans may have slightly larger load capacity (I haven't looked) than Expy's, but they theoretically should because they are built somewhat lighter than a Ford Expedition and come with similar light duty original tires. The increased available payload result is similar to your minivan, the light vehicle weight of which allows a greater payload on the marginal OEM spec'd tires. Factory tires, and their meager ratings, are usually the weak link and the load range can easily be upgraded to safely carry extra weight on any vehicle.
Someone suggested an older Excursion SUV like I have if you wanted to haul your large family and also pull a camper. The reason they thought that would work better is that truck has a 3/4 ton chassis. But just FYI, the older truck I have is rated at less than 1800 pounds load capacity, just barely over that of the newer 2012 Expy's 1500+ pounds. Considering the huge campers (up to 40') often pulled by Excursions is why I believe the near capable Expy would have been just fine for your needs with a smaller camper (should you ever reconsider an Expy down the road). It is probably important to mention that only about 1/2 to 2/3's the trailer tongue weight ends up on the truck because of weight distributing hitches, so I see a couple hundred pounds, or so, of actual resultant tongue weight as no big deal if they remain within tire ratings.
An odd thing you might encounter is that campers are often sold with marginally rated tires also. In some cases, the gross payload is claimed to meet in excess of the total weight that the tires could hold. This does lead to blowouts on these relatively small tires. This is worse than vehicle manufactures who tend to be pretty conservative the other way, especially Ford, all in the interest of liabilty I assume.
Good luck whatever you decide and have a great holiday season!
Wes
