blt2ski
Dec 22, 2013Moderator
CKNSLS wrote:
If you have an at fault accident the other party's lawyer will care towing that much overweight.
Care to show an actual case from a court that this will happen? other than what I personally believe to be a totally false setup from some dune post in Ca IIRC!
In my state any how, ie washington, if the person in the van is under its max axel wt ratings, has the proper PAID for licenses etc, even if he kills someone, he will be legal from a wt standpoint. There are OTHER laws that will hurt the OP, but being overwt in his situation is NOT going to be an issue!
This shows the metality of some, where if you have a 3.73 axel engine combo, rated to 14000, then put a 4.10, you are good to 16K.......an axel ratio makes you 2000 lbs safer towing?!?!?! with everything else being the same?!?!?!?! yeah right!
Marty
