As other RVer's have indicated, your 1/2 ton Dodge truck is marginally capable of towing your trailer. What I would suggest is that you load up your trailer to approx. the same weight you would normally towing when RVing, then take a day trip with varying road conditions i.e. up and down some hills, against the wind. This will give you a more realistic idea of your trucks towing capacity and ability to control the towing of the trailer. This trip might reveal that you need to buy a different type trailer hitch/sway control. I had great towing experiences with the Reese Dual Cam trailer hitch. The Reese provided good sway control capabil
If financially possible, I personally would buy at least a 3/4 ton Dodge truck. I currently have a Dodge 3500 1 ton for towing my 34' 5th wheel.
t
