Mbiviano's avatar
Mbiviano
Fan motor issues
I have a 2015 F350 and the fan motor keeps going out. Once at 30k miles and now at 40k miles. Ford says it's not uncommon. Anyone else have this issue? Should I look at aftermarket fan motor that's more robust? I predominantly use truck to tow 5er and in mtns.
  • Mbiviano wrote:
    OP here...I am referring to the radiator fan.
    Is that not a clutch fan? No motor?
    If a dealer is referring to a fan motor, find another one that knows what he's talking about.
  • enblethen wrote:
    Are you talking auxilary fan on the radiator? I would get dual fan after market.
    Powerstrokes have an aux cooling fan?
    Like full size belt driven fan and an add on electric pusher fan?
  • I have the exact same truck and no issues with the fan. I can see one because things do go bad, but two or more??
  • Are you talking auxilary fan on the radiator? I would get dual fan after market.
  • Go to the truck forums.
    I’d bet Summit Racing has something HD.
  • 30k to 40k on a fan motor is “normal?” Baloney!
