donn0128
Apr 12, 2018Explorer II
No, its all inside.
First things first. Take the screen and trim ring off. Check for a piched or broken wire. When my roof was replaced several years ago the idiots did not connect the wires. You can check for voltage at the wire nuts. Check to bensure you can actually manually open it. Often the cover will stick to the gasket.
If you have power, and if you actually turned it on, and if the motor does not spin, and if you have tried to manually open and that works then likely the motor is dead. But Im guessing you have a loose connection or a broken wire.
