wnjj
Apr 12, 2018Explorer II
Harleybullet wrote:
Well I took off the handle and screen... there are the 2 yellow wires coming from the chase in the roof they are hooked to the white and green fan wires and the are 2 black wires from the chase in the roof connected to the fan black wire... no fuse can be found along either set of wires.
There is a nut holding the fan blade on....if I remove it I assume the fan blades will come off but what about the motor... cannot see any screws holding the whole unit in place....Do I go in from the top ???
Is there any where else in the TC that the fuse maybe hiding?
Dave
Our FF switch is in the housing with the fan. When you say the wires go up into the chase, does that mean your fan switch is wall mounted? Is it multi speed or reversible? Can you see the wires all the way to the fan motor? Like others have posted, ours has a black round push and turn fuse holder in the corner. There should also be a main fuse in the DC panel which may also power other circuits.
Can you post a picture?
