bigfootford
Apr 23, 2018Nomad III
Harleybullet wrote:
OK guys you were right it is a Shurflow.....I hot wired it from the adjoining light and it works....I am assuming there is a short in one of the wires in the chase....thanks to all. Dave
Great.....
I believe that the Surflow design is superior to the fantastic fan, especially with that variable speed. It also can move more volume of air per amp! Blade design!
Yes the motor has trouble. Biggest is that it chirps/clicks at times. It also can thermal out with heat. It has a auto resettable breaker internally. The lid is black...hahahaaa... I did a temperature check at about 3/4 speed.... 100 deg day.... the motor will thermal out.
My motor was chirping so under warranty I got another motor. The new motor chirped/clicked too.
I wondered why so I took apart the motor expecting to see needle bearings instead of balls for the armature. NOPE, Ball bearings.... to this day I do not have a clue why it will chirp sometimes. Sometimes it will run all day.
Another problem is that the motor at times will not start. Both motors do this. I believe this is due to the spacing of the commutator contacts. So moving the fan just a bit CCW or CW and off it goes.. Pain in the Butt.
I did reverse engineer the circuit that controls the speed... It actually steps/pulses the voltage via an op amp and associated circuitry.... Just like the speed controls for RC electric motors. The speed control knob just varies the input voltage to the op amp.
So that's my story.....
I believe Surflow discontinued the product because of the motor issues...w
Jim
