speediq99's avatar
speediq99
Explorer II
Apr 23, 2021
Fast tongue jack
Any recommendation on a fast tongue jack for a 7500lb TT.
We just bought a new TT and the electric jack is extremely slow.
Thank you
MC
  • Caution with the folding foot, unless you bungee it up while traveling it has tendency to drop down.
    And It tends to fold up on uneven ground.
    Then it's broken. It has a 1/2" dia, spring loaded steel pin that must be pulled for it to move from either position. Drop the tongue hard enough (like my dealer did) and it will break. Otherwise it will never move on its own.
  • May want to check the wiring of the jack to the battery.
    A few years ago I installed a power jack and didn’t pay close enough attention when making the electrical connection (2x6 volt batteries) which resulted in having only 6 volts feeding the jack. It worked but was extremely slow, like taking about 5-6 minutes to fully extend. A simple rewire to provide a full 12 volts fixed the problem
  • QCMan wrote:
    I was serious with that comment. My time is valuable. Maybe yours isn't.
    Cant be that valuable you've posted worthless comments twice.
