ShinerBock
Jun 26, 2019Explorer
RobertRyan wrote:They are not the same frames from what I have read. The US Colorado/Canyon frame is longer to accommodate for the longer beds in our market. The US frame is also supposedly 40% lighter due to the use of "high-strength steel" while still having the same yield strength according to GM
I do not think so as you can get 10ft Utility beds on the Colorado here US payloads are a lot less
Well then take it up with GM because their own executive said the US version is longer and wider than the Holden version. Payload are a lot less in the US for these trucks because
1)The GVWR of the class these trucks are in is capped at 6k so having a 4.5-5k curb weight does not leave you with much room even if the truck could handle it.
2) Unlike other market, the NA market has more truck choices so truck makes don't have to build these trucks to handle more weight since we have bigger trucks for towing/hauling more weight without needing a special licence. Most people would rather have a larger truck here anyways which is the reason why our large trucks outsell these smaller trucks almost 5 to 1 in the US.
