bgum
Sep 07, 2020Explorer
264sr you either don't tow much or have been very lucky. Our tire problems have been: the MH picked up a bolt the size of my thumb on the driver side rear inner tire, Our first Airstream had rapid failure which could be called a blow out, the teardrop picked up a piece of steel, the 5th wheel had a sidewall may pop. In half of the cases it was the tires fault, in the other half it is our wonderful roads. We try to run the best available tires and check them daily. If I were the OP I would use light truck tires.
