MarkTwain
Sep 07, 2020Explorer
rollindowntheroad wrote:
I purchased a 2018 Prime Time Tracer 253Air in April. For Father's day my daughter got me a Good Sam membership with roadside assistance, thank God!
I have used the TT once a month since May. Have had 3 tires blow out, 2 just this weekend, Labor Day weekend. It has been 3 different tires, different positions on the TT. The TT has double axles. Labor Day weekend had one blow out on my way to my destination, then another one on the way home on Monday. The tires on the TT when I bought it are Towmax 205/75R14's. The TT is not overloaded as I only use it for weekends so just the minimum stuff needed. The guy that came to change it on Friday said I need to get either D or E load rated tires. Currently they are C rated. He said they are just to light of a tire for a TT. Saturday I got another tire however couldn't find a D or E rated one any where. So ended up with another C rated just so I would have something for a spare. Was told by several tire places that to get the D or E rated they would have to be ordered. So before my next trip going to be ordering 5 D or E rated tires and put them on. Hopefully this will solve the issue. If not don't know what else to do.
Has anyone else had this frequent of blow outs or is it just my luck?
BTW, I can't say enough good about the roadside assistance. After you call they get ahold of someone that's closest to your location. Whoever they get ahold of then send you a text message with approximate arrival time. Friday night they said within an hour, actually got there within 45 minutes. Monday they said within 35 minutes and got there within 15 minutes. So way to go!!!
One strange thing is that all 3 blow out have happened on the same Hwy within about 10 miles of the same spot. No work is being done to the road and didn't run over anything. Guess I should go a different route next time.
Towmax tires are cheap tires which accouts for all your blow outs. I bought a new 5th wheel trailer that had new towmax tires, I told the dealer I would not buy the trailer unless he replaced all 5 tires with Good year tires. Do your own research. I suggest you also go to 15 inch rims and put at least "E" rated tires. I have 16" rims with "G" rated tires because I have a heavier 5th wheel trailer. Personally I prefer to have a heavier rated tire than I need.
