Sjm9911
Sep 09, 2020Explorer
2112 wrote:rollindowntheroad wrote:I was being extremely conservative with the 1350lb tire load estimate. Your TT fully loaded to GVW would have close to 1700lbs per tire. Load rated C tire are marginal at best for this TT. Especially a rear kitchen with very little cargo weight up front to counter the kitchen weight.2112 wrote:
OP's 2018 Trace 253AIR is a rear kitchen. If he has the kitchen fully stocked and carrying a full tank of fresh water, his 4 tires are probably carrying a guesstimated ~1350lbs each. Well under his Towmax ST205/75R14 Load C rating of 1760lb @ 50lbs cold.
I think his problem began when one blew for whatever reason, most likely a rear. At that point, the remaining 3 tires are carrying 1800 lb and compromised. Most likely the one on the same side of the blowout is carrying much more. It just snowballed from there.
Again, my guess is he eventually lost both rear tires and one of the front tires. Rear kitchens a tail heavy if not loaded properly.
You are correct, my TT is a rear kitchen. However it is never fully stocked as I use it just for a weekend once a month. All 3 tires did not blow at the same time. The first to go was the driver side rear. This weekend the passenger side rear blew on my way to the campground. On my way home the passenger side front went. Each time I heard the tire pop I pulled over immediately.
Yup. Probably overweight. Don't tires have a lesser weight rating for dule load also? I dont know whats on his camper but i bet it wasn't enough.
