aftermath
Sep 13, 2020Explorer III
To the OP, glad you got this figured out. You will be happy with the New Goodyear tires.
In the first 5 or 6 replies no one talked about the load range of your original tires. They were quick to talk "China bombs" as if this was the issue. I purchased a new Starcraft hybrid back around 2005 and it came with LRC Carlisle tires. The maximum payload of the tires was just slightly above the GVW of the trailer. Very close, almost no cushion. I lost a tire soon. It was NOT the country of origin that was the issue it was the poor match of tire to trailer.
When people say "air them to the max" this only is true if you have a low payload capacity. To get the maximum payload you have to have the max air pressure on the side of the tire. Anything less will cause the tire to flex which builds heat which weakens the tire which....well you know all about what happens next. I now have an Airstream and run LRE tires which might be a bit of overkill. They are the Carlisle HD Radials and have been fantastic tires. Over 20K miles on these and after I set the PSI to 70 in the spring, I usually don't have to adjust them. The LRE gave me tires with speed rating of 81 MPH, with max inflation of 80 PSI. I will never go 81 and I don't inflate to 80 but I do like the cushion of safety.
I prefer ST tires. They are designed for trailers and have stronger sidewalls which help deal with the flexing they get when turning tight corners and backing up. Dragging tires in camping spots does stress the sidewalls. Again, the most important thing when it comes to tires is to make sure you have a load range sufficient to carry the weight of the trailer with a good amount of cushion. Best wishes.
