Huntindog wrote:
For once I agree somewhat with Larry on this.
I do not like his approach though. I find the screw type jacks difficult to use... It is getting close to a permanent Mobile home type installation. Great for stability, but not so great for ease of use.
At least Larry does admit that even with his approach, not all movement is eliminated.
Every person will have to make their own decision on just how far they are willing to go to eliminate movement. If you want it rock solid, it can be done. But there will be compromises that need to be made in ease of mobility to achieve it. There is no right or wrong.
As always, it is your choice.
Well I have found that it takes close to zero difference in time in using the jack stands over the factory stab jacks that were on my trailer originally. On the movement, be careful and read closely what I said. The reason I still can have movement is if I'm not careful if walking around in the end of the trailer and that is there only because I know it exists ONLY because I CHOOSE not to try and stabilize that movement source NOT that it was still an issue with the method I use to otherwise stabilize my trailer. Otherwise my method prevents any noticeable movement whatsoever for the rest of the trailer.
Heck for one night stops I don't use anything except to take a little wt off the hitch and just accept the movement for those nites when I'm traveling to my ultimate destination.
As I said a big plus for us is we now don't have "WEE ONES" running/jumping/etc. ... it's just use two slower moving ole folks now.
Larry
