AirForceAngler
May 08, 2014Explorer
It will pop off pretty quickly without the proper prep, especially if there's a crack underneath. Your best bet is to stop-drill the crack, rough sand the areas around the crack for adhesion, apply some fiberglass mat with resin, let this dry then sand it to feather it in and make as smooth as possible. Then just use a filler putty to smooth out for priming and painting.
44,066 PostsLatest Activity: Jul 25, 2018
