bobsrvnet's avatar
bobsrvnet
Fiberglass TT - Chalky Look - Wax Recommendations?
Hi all, with our 2002 TT with smooth fiberglass outer finish on all sides I have noticed it to be looking fairly chalky white on the surface. Is there any way to bring back that shiny gloss finish utilizing a typical paste wax? I have tried 'Rejex' and did not have much luck.
Any tips would be greatly appreciated!
  • You can test a small spot with a "cleaner wax". If it isn't too far gone, you may get decent results. You may end up having to do a full blown polish, then a good top coat wax to follow to get it back the way you want it...
  • harold1946 wrote:
    The chalky looking stuff is oxidation and has to be removed before waxing will do much good.
    True dis! If the surface is oxidized and you apply a wax or sealant, you will be trying to polish chalk and the underlying surface.
    I like to use one of the TSP substitutes like Jasco brand to remove oxidation.
  • The chalky looking stuff is oxidation and has to be removed before waxing will do much good.
