Robby9 wrote:
To answer the questions:
Catalina Deluxe 30qbs vs. Keystone Cougar 31SQB
Height and width appear the same to me. (same size tires too)
The front cap of the Cougar is different in that it encloses the propane tanks and the battery.
Wind, hills and speed were not a factor.
I think you nailed it- is this your new rig? It's actually a few inches taller than the Catalina, BUT that rounder, less broken surface up front is bound to reduce turbulence. I think that swoop up front that swallows the tanks is brilliant. The way the front side edges sweep down and away probably helps, too.
If any part of the design contributes to a fuel-use difference between these trailers, my money's on this front design rather than the materials.
The Catalina's (below) exposed tanks probably do create more turbulence than the above smooth lines.
