Grit_dog
Jul 02, 2022Trailblazer
JRscooby wrote:
Glad you solved the problem. Are you open to suggestions? Pull all the wheels, and put anti-seize on all the hubs to reduce future problems.
Bingo! Spot on. In my garage that stuff is like Franks Red Hots. I put that sh__on everything!
(Except where loctite is actually required.)
@Bedlam, can’t believe 1 year here stuck the rim to the hub. I’d also put a little no stick um on the rim mating faces to prevent future occurrence.
