- JRscoobyExplorer II
Geo*Boy wrote:
Wow Bedlam, my truck has never seen winter salt and never will, but the next time I have a chance I am going to pull the duals and put never seize on the hubs.
Front too - Geo_BoyExplorer IIWow Bedlam, my truck has never seen winter salt and never will, but the next time I have a chance I am going to pull the duals and put never seize on the hubs.
- JRscoobyExplorer IIGlad you solved the problem. Are you open to suggestions? Pull all the wheels, and put anti-seize on all the hubs to reduce future problems.
- LwiddisExplorer III’m interested in those pictures, Bedlam. Never encountered this issue.
- IB853347201Nomad II
BobsYourUncle wrote:
I carry a lot of tools with me including an 8 pound sledgehammer. I put a block of wood across the wheel so it straddled the top of the rim and clobbered it with the sledge. It took a few tries but I eventually dislodged it. Gotta be careful not to hit the rim directly. I rotated the wheel between hits.
Sledgehammer or pry bar, it's what the tire shops use..... - BedlamModeratorI found running ratchet straps through the rim and putting a wooden block centered on hub put enough even force on the rim to free it. Just when I got it free, I got a call that service was 5 minutes out. I'll post up some pictures tomorrow when we are on the OR coast.
- Cummins12V98Explorer IIIShock and awe. Hit it with some type of steel you hold in one hand and big hammer in the other. Place steel between the lugs and WHACK it.
- I went through that a number of years ago. Try as I may, that thing wasn't coming off the hub.
Here is how I freed mine:
Mine was rusted onto the hub at the very back. It was the rust holding it on there. - I would drive very slowly with the lugs loose.
- FishermanExplorerYou might be able to get a small steel chisel between the rotor/drum on the rim openings and give it a couple of wacks with the tire iron. it's worked for a couple of cars that had seized rims. Then apply anti seize to the mating surface, sparingly. Another trick I used on trucks if you don't have a heavy load, loosen the wheel nuts about 1/2 to 3/4 turn and make some really sharp left right turns, that often cracks them loose too.
44,049 PostsLatest Activity: Sep 03, 2025
