valhalla360
Jun 21, 2022Navigator
Bedlam wrote:
There are two-part hitches where the hitch head and cradle separate to make them lighter. Anderson fifth wheel hitches are lighter but some people feel they are not up to the task.
If your truck has pucks or a gooseneck to mount a hitch, you have almost a flat surface and not much to push up on the under side of the camper. If you have to install rails, you will need to build up the bed surface to those rails before loading the camper.
Just leave the hitch connected to the trailer and lift the front of the trailer. No need to break it down. It can easily support the hitch weight (just make sure to lock it, so someone doesn't accidentally release it and drop it on their foot).
But I think the OP is talking about the bed rails.
- If you get the puck system, there are no rails.
- You can cut plywood of the same height to fit around the rails.
