ACZL
Jun 02, 2015Explorer
As you can see, the replies are all over. I agree that a gasser w/ either 4,10-4.50 gears would work, but you will be doing some serious twisting of the motor and lug on hills. MPG's would be less w/ the gas both in towing and everyday driving. Germany has figured out the DEF system as we have a '13 Passat TDI diesel w/ 60K and no problems (knock on wood). At work, I have a '12 Detroit Diesel DDT13 and has had a few DEF issues. Freightliner dealer said about 70% of truck to be fixed have some sort of DEF issue w/ them hence at shop to be fixed. When the DEF works right, they are all great. When not, they all stink.
As for truck itself, we had a '03 F250 SD w/ the 6.0 and 3.73 gears and towed rig in sig w/o a prob. Fully loaded, pin was 2,000 and 5er was 12,800 and still had a 1,000 pounds to go before being maxed out on 5er. Yes I was over on truck, but as for pulling, she did a very good job. Newer trucks have higher tow ratings than early 2000's did. I think you'll be fine w/ a 350/3500 SRW. In the case of Ford's 6.7, 3.55 gears is pretty much the norm in SRW. 3.73-4.10 is offered in dually only, BUT I want to say someone said in TX you could get a SRW w/ 3.73 gears (can someone confirm this). Is the OP looking at what kind of cab and 4x4 or no? Friend of ours has a '05 GM Dmax CC,4x4,3.73 gears and tows a 5er in neighborhood of 15k w/ no probs. I wouldn't on a 3/4 ton, but many have.
As for keeping it till 80,000 miles, IMO that's a crapshoot. Yes your still within warranty, but like AP said, it's just starting to get broke in. Seems like your going to take a good hit when it comes to up front cost of diesel engine and never see the full life of it in order to recoup your initial investment. I was asked by my F-I-L when I had my '03 if I'd get another diesel again and I replied w/ a yes (despite some issues I had w/ the '03). Gas does has it's advantages along w/ diesel. I just want to be on safe side and be sure I have enough motor to do what I want now and down the road if need be. Had my '03 for 11 years and 160k. God willing, current ruck will do the same or more.
44,066 PostsLatest Activity: Jul 25, 2018
