Old-Biscuit
May 03, 2015Explorer III
Hannibal wrote:
Newer tanks have a ruptured pipe valve in them. I went through three tanks, two regulators and a hose with our WeberQ before I learned this. Some are more sensitive than others. Now I just barely, barely crack the valve, watch the hose tighten up like a snake for about five seconds, and then open the valve fully. It's the sudden rush of gas through the hose as it pressurizes that sets the safety valve. If it's really quiet and you crack the valve too fast, you can hear the safety valve click closed. Once closed, you'll still have enough gas in the hose to run the grill at very low flame for a few minutes before it fizzles out. This really through me for a loop. I was ready to hurl the WeberQ in the bay. I'm glad I didn't. Now that I know, it runs great.
:H
'ruptured pipe valve'??
DO you mean 'Excess flow valve'...........that is an internal component of the ACME Nut
See this post
'samsontdog'
That propane cylinder issue......
You had it filled last season. You banged it on concrete (trying to unstick OPD I take it??)
When filled do you remember if the 'liquid level bleeder' valve was opened during filling process OR did they just go by weight?
OPD Float could be jammed if cylinder was overfilled.
As suggested crack open 'bleeder' valve and let some propane out.
Do this with cylinder connected to hose that you know flows propane and then check inside RV if you get flow (cylinder service valve can be open while bleeding propane off)
CAUTION: Bleeder valve will spit liquid propane if level is normal and especially if overfilled. Use heavy gloves to protect hand.
Slow and easy......
