- Jim_HillExplorerJust noticed the other two posts. More good ideas.
Jim - Jim_HillExplorerThanks for the tips. I'll purchase linky2 and Water thief.
Jim - SoundGuyExplorer
2oldman wrote:
You can lift containers, but it's unlikely you'll be getting 50 gallons that way.
Carry a set of fresh water containers of your choice in the back of your TV for collecting water and you won't have to lift anything. Back at the trailer use a 12 vdc pump, again of your choice, to pump that water from the containers into your trailer's FW holding tank via the FW gravity fill.
Fresh Water Transfer (7 pics)
Collecting water one container at a time using a wheeled luggage cart as suggested earlier works but trust me, having to make repeat trips to the campground water supply gets old really quickly. - 2oldmanExplorer IIYou can lift containers, but it's unlikely you'll be getting 50 gallons that way.
- Campfire_TimeExplorerGet one of these from a rummage sale. Use bungee cords to strap down one of these. And mount one of these to a board, and get it hooked up to some plastic water hoses. Make a 12 volt connection somewhere on your trailer that you can hook up the pump with alligator clips to run it. Mount an on/off switch to the board and your good to go.
My dad did this years ago and never has to lift anything. Easy peasy. - korbeExplorerI will take a few trips to the spigot with my 6-gal green container with spout (from Walmart) where the spout fits into the fill hole.
- pianotunaNomad III
- Iraqvet05Explorer
44,051 PostsLatest Activity: Sep 22, 2025
