afidel wrote:
ktmrfs wrote:
1ed wrote:
My tanks are 30 pounds and weigh 55 pounds when full. All of the exchange places in my area ONLY swap the 20 pound tanks. Hence the question.
many gas stations, uhaul locations, etc. will fill propane tanks, including the 30lb tanks. And IMHO swapping tanks is a boondoggle. First the cost/gallon of propane is much higher than filling, second most if not all only give you a partially filled tank
I only use tank swaps when my tanks are expired, cheaper than getting them recertified.
yup I've used the "tank swap" option with an expired tank as well. In fact the pump jockey at the location helped me look through the tanks to find one in good shape and nearly new.
