sbodi4d's avatar
sbodi4d
Finally getting a camper!
Hello all.
Been lurking here for a few years, posting sporadically. Hopefully by this time next week, we will be the proud owners of a new 2014 Rockwood HW296!
I have a 2007 Silverado 1/2 ton truck to haul it with. My question is, should I get a WDH or just go with the TV the way it is? Truck has a factory installed towing package rated at 5000 lbs, towing weight, and 600lbs. hitch weight. The new Popup is rated at 373lbs. hitch weight, and 4573lb. GVW. Can't decide whether a WDH would be needed, or not. Hate to spend the dough if it is not needed. Thanks for all the advice I have gleaned so far.
  • I would try it without first. The tongue weight will increase as you put stuff in the pup, I would load it up like you think you would for a camping trip and see how she does. If the tongue is too heavy then you can get the WDH. My little 8' pup has around 325 lbs on the tongue when I am loaded up to travel.
    Those highwall Rockwoods are nice campers, you are sure to enjoy it.
  • If your ball right is not mounted in your step bumper I would try it out first.
