wnjj
Sep 29, 2013Explorer II
NRALIFR wrote:
I really like the "turn-around" extension I had paved off the lower driveway. I can now drive in normally, and get turned around easily to back into the garage. Before, I had to turn around on the surface in front of the upper bay, and then back all the way down the curving driveway into the backyard. Much easier this way
Have you tried pulling forward into the driveway extension? That way you only need to change from forward to reverse one time, have much less distance to travel and the best part is you get to back toward the driver's side when turning which is much easier.
What a great feeling to store it away out if the elements, isn't it? Ours has been spoiled since day one with an insulated, heated shop.
Oh, and are you sure the door is big enough? It looked like a tight squeeze backing In there. ;):B
Thanks so much for allowing us to watch over your shoulder.
